How to measaure polygon area with arc-edges?
This feature help you measure Polygon area with arc-edges.
  1. Click Polygon(arc) area
  2. When you encounter a straight line, left-click on both ends of it. While encountering an arc, left-click on the arc itself.
  3. When reaching the last point, just right-click and it will automatically find the starting point and close the polygon and left click to put the measurement.
Attention:
  • An arc could be automatically recognized when the mouse turns into a small white square. If the mouse turns into a small yellow square, it means that is is not an arc but a polyline that consists of multiple line segments, and you need to select them one by one for measurement;
  • When encountering a broken line segment, click the endpoint to capture it before continuing to measure;
  • When the defaulted drawing unit is mm, you can click the settings function to display the measurement in square meters;
  • Clicking the space key on your keyboard to take a step back when you selecting points for the polygon.
  • The arc can be interrupted if you think it is too long. Just move the mouse and find the intersection point where you want to stop it and left- click on it.
Watch the tutorial video here:https://www.youtube.com/watch?v=IKkAg3A6vCo
Category: CAD Reader for Mac
gu***om
